Riveninside
- Jul 9, 2005
hey all. i'll try and explain this as best as i can... i'm using my laptop right now so i can still check the net.
ok, well i got my computer back from my otherhouse and set it up, started playing on it, and all of a sudden everyhthing just turned up and froze, so i restarted it, got back on and it did the same exact thing, but it's werid, it used to vary from how much it would let me be on. than it wouldn't send any thing to the monitor, so first though, my video card went out, so i used a known good one and tested it... still nothing. so i went and bought a new video card and a new case for shiz and giggles, and even swapped to another known working motherboard just incase something was screwed with that... (went from a leadtek K7nCr18-d pro to a asus A7N8X Deluxe) and still nothing, so i tried 2 different processors and still... nothing comes on the screen. all the harddrives and everything is powering up. even the fan on the videocard. so i know there is power going to the video card. but still there is no signal, i even swapped to a different computer to test both my moniters and they both worked, but something is really screwed somewhere in my system...
that was the explanation now the simple one
Nothing coming on screen
Swapped 2 video cards and bought a new one
Swapped another motherboard on
swapped 2 different processors
everything is powering on
tried 2 different Power supplies (450w and 500w)
tried 2 different sets of ram
still nothing coming on the screen.
any ideas??
i'm tempted to build a whole new system but i dont want the same sorta thing happening all over again on the new one
also i bought a new motherboard and it should be here in just a few days (bought one from new egg so it should be fast shipping) and i'll try that.
any ideas??
