Hardware noob, needs help with issue
Laffles
Getting blue screens suddenly and I don't know why, I was getting fps drops in BF3 cq maps and a friend helped me update the drivers on my mobo, which fixed it.. could that be the cause? I'm totally lost when it comes to any kind of issue, so any advice is really appreciated.
The first time it happened I got loads of error boxed for all programmes running in the background, 'blah blah has stopped working' and then got the bluescreen'
specs:
Intel Core i5 2500K @ 4.7Ghz
corsair H60 Water Cooler
Gigabyte Z68A-D3
8gb ram
Crucial 64GB SSD S-ATAIII 6.0Gb/s
1TB S-ATAIII 6.0Gb/s
GTX 670 Asus direct 2gb
PSU: 700W Xigmatek
After a soft reset it hangs at the boot screen, have to turn off and turn on to bring it back
Just happened again :(
These are the application errors I get before my system crashes
DoF9
This can be indicative of a problem with the page file. See this Microsoft article.
Microsoft said:
Welcome to Microsoft answers.
This might be an issue if the paging file is not setup properly on the computer, follow the steps below to setup the paging file:
1. Right click on Computer.
2. Click on Properties.
3. Click on Advanced System Settings.
4. Click on settings in Performance under Advanced Tab.
5. Click on Advanced Tab in Performance Options Window.
6. Click on Change.
7. Uncheck “automatically manage Paging File size for all drives”.
8. Select C:/drive.
9. Select “System Managed Size”.
10. Click Set.
11. Click OK.
12. Now restart the computer when it prompts for a restart.
If the issue still persists, then you may try Memory test, follow the steps below:
1. Click Start.
2. Type in Windows Memory Diagnostic in Start Search.
3. Click on Restart now and check for problems.
This will fix any memory related issues on the computer, make sure save all the files before you perform this test.
If the issue still persists, then I suggest that you run virus scan on the computer and check.
It could also be due to your SSD not liking the new motherboard drivers - check to see if there's a firmware update available for the SSD. IIRC this particularly affects OCZ SSDs.
specs:
Gigabyte Z68A-D3
8gb ram
PSU: 700W Xigmatek
Have you tried the CPU at stock settings?
