Harddrive spinning
crazyboy515
my hard drive seems to be spinning quite a few times today while everything was idle. i restarted the comp, and even if im not doing anything, it still spins (i can hear it) what's up? my computer seems to be running smoothly
spyware maybe, or system updating, or maybe the Government is scanning your machine.
Its just Vista.
Its just defragging, or indexing or something.
You should still check for spyware, but I would bet that its just Vista doing its thing.
Its just Vista.
yea i guess so. ran a scan,nothing found that is bad. anyways thanks for telling me this.
yeah.. mine used to do that like all the time, and then it stopped
no idea but all i know was that it was doing the idle stuff vista is programmed to do
Power saving feature. Default setting for Vista/7 is to shut off drive after 20 minutes. You can change the settings in control panel.
