hard drive problem
kp3509
My hard drive has recently developed a problem
At ramdom times it stops spinning and keeps trying to spin up again and my computer basicly freezes or crashes. The drive works sometimes and I can access all the data but it dies everyonce in a while. I think my other partition on it works fine. Anyone know how to fix it?
Sounds like the drive may be dieing...backup anything valuable. After you do that run some sort of a disk checking program, the manufacturer should have one. Another option is you have linux run badblocks and see if you can get it to have problems.
