nightanole
- Feb 16, 2003
Well i use a hard drive as a back up (how many dvds would that take????) and i wanted to run this by some one. I use sataII. Im set up for hot swap. And i thought about installing a hard drive power switch to shut off the backup drive when im not backing up. I could use a 2 pole single throw switch to cut the power to the 5v/12v lines. This would protect it from power failure of the ps or lightning and from death by virus or something else as nothing could access the hard drive. The hard drive would be grounded to the case so the only way to damage it would be if some odd voltage went through the sata data line, which is dam near impossible due to power supply failure or lightning.
