Hard drive failure???
cxz001
Hey,
I just ordered a new hard drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16822145166
It came. It worked for about 4 days, and then I notice my games would hang for like 20 seconds some times....
I reboot the system, and system would not start, because the HDD clicks clicks clicks for like 10 minutes, and in BIOS i can't even find the HDD!
Does this mean this HDD is dead/??? Is it due to overclocking CPU and increasing voltage? How do i restore my data!!?
Try plugging the drive into another power connector. Also try a different socket on the motherboard. And get another cable and try that.
It kinda sounds like a dead drive to me though.
Overclocking the CPU or playing with the CPU voltages will have zero affect on the peripherals. They run off of the 12v and 5v straight from the power supply. The voltages you change when you adjust the vcore or memory voltages are internal to the motherboard, not what is being fed from the power supply.
Don
# Does Newegg.com pay the return shipping cost for defective merchandise?
No, Newegg.com does not pay the return shipping cost for defective merchandise. We are not responsible for product defects, because we do not manufacture the products we carry. However, if you pay to send the item back to Newegg.com, we will replace the item and ship the replacement to you at no charge. Newegg.com will employ every resource it has to ensure that your item is replaced promptly, without hassle.
Nope.
No retailer that I know of does.
You may want to check on Hitachi's website. They may offer a better deal than Newegg. But the replacement you get from them may be refurbished.
Don
