freddiepm61
- Oct 19, 2004
I have a Lian-Li V-1000 case, with two 74gb raptors, and a 200gb western digital.
The 74 gb raptors are at top and bottom, and are at 29&30c. right in front of the fan in the full force of it (the edges).
However the 200gb wd hd, which should be cooler is not at all. it is at 41c, which is too hot. putting at the back of the 2x3 hd cages in the middle makes it hotter, and top and bottom is the same, as there are the other hds obstructinfg air flow.
therefore, what is a good hard drive cooler, which is relatively quiet?
I can chop out the back hard drive cage, and stuff the proabab;y 5.25" cooler in there....
I have all silenx 120mm fans (4 one on an xp-120) and arctic cooling gfx coolers.
So it is pretty quiet, and I don't want it getting much louder.
The zalman heatpipe? good/bad? or do I need fans? if so what is good?
also, what is a good hd temp? for high stability?
thanks alot
f
thanks alot
f
