HAF 932
likenew
I just bought this and it arrived last night, looks great, can't wait to put stuff inside it! Curious about what others have done with it though. The big fans can be replaced with 120mm ones, is it worth it to replace, or rather should I? It also looks like quite a bit of dust will be getting in with all those extra holes, seems like a pretty open case! Is dust a problem? What do you do to be as dust free as possible?
I think thats it for now. Any other thoughts on the case or things I should do to it?
I replaced my top 230mm fan with 3x120mm Cooler Master R4's. It increased airflow and dropped my temps ~1-2 degrees. However they're a little noisy, I also changed the 140mm stock fan to a 120mm R4 and added another R4 to the bottom next to psu mount. My case doesnt get too dusty, but I spray it out once a month or so. I can post pics if youd like.
Sure, I would very much appreciate it =-)
I'm still a ways away from completing the build, just buying here and there, but I'm already excited =-)
Get yourself the HAF 932 filter kit. It's a bit pricey but probably worth it in the long run. If you don't want to spend that much, you can buy yourself air filtering material for about $10-15 and cut out and tape it on yourself.
