HAF 932
zzzttt1
Anyone know where i could pick up a new top fan 230mm(I think) my is getting annoying,buzzing noise and and can some what feel the output of the fan was not like it was two years ago.
Also how hard is it to replace this fan?
If I wasnt deployed Id send you one of the ones I removed from my HAF 932 case.. Although I would try Cooler Master first, a lot of companies are good about replacing their products bits and pieces if there is an issue.
any Cooler Master Mega Flow 200mm fan should fit. Its basically the same, 190mm fin diameter. The 230mm have that extra side width that makes it 230 mm. Same rpm too.
You can also get the Storm Force 200 which is also the same except that it runs at 1000 rpm, but you will need a 2 pin connector for its LED.
This is of course assuming you are unable to get a free replacement, as previous post suggest.
The only difficult thing in replacing the fans are the hexa shape screw that the stock 230 fan use
You sure it's not just the case rattling from vibration? Try placing your hand on the front grill to hold it, sometimes that grill rattles cause it's slightly loose.
Ya, im not sure what it is, but its sure getting annoying to me,
I made a little video,you can hear it, but i have been able to find it.
http://www.youtube.com/watch?v=RfKl1aUAUu0
Thanks, it sure sounds like the top fan to me, but can not tell, I have Stomped the CPU fans and it was still buzzing/vibrating So i can rule out the cpu.
Temps are pretty good, only thing on the warm side is my Vreg which idles around 46 and under a load goes up to around 53 to 56Max C. which is little high but fine I think
