duncann
- Oct 30, 2005
Thought I'd post my observations about the 970 strix. I had to send back two of these to the place I bought them from (one from newegg and one from amazon) because of defects. One had occasional massive bouts of coil whine upon turning the computer on. Another had ramdom flashing dots on any open windows and far cry 4 started to crash immediately upon loading a save game.
One of the programs I use to get info about the card (temperature, voltage, etc.) is aida64. The first two of these cards had approximately the following while idle at desktop (windows 7 64-bit):
gpu tdp%: 10%
gpu vrm temp: ~39C
gpu vrm power: ~10W
gpu vrm current: ~11.50A
The replacement card from amazon has the following:
gpu tdp%: 10%
gpu vrm temp: 30C
gpu vrm power: 1.25W
gpu vrm current: ~1.5A
At first I thought these differences might be because of the driver. The first two I used max 344.75. The new card I used 347.09 immediately upon installation into the computer. So I decided to try 344.75 on my current card. Still get the same readings. This suggests to me a hardware change somewhere (probably vrm circuitry). I tried looking for any rev numbers on the card itself but couldn't see anything. Maybe I didn't look close enough. Bios versions on all cards were the same (I saved them all as a file using gpuz). There are 10 or 12 bytes difference between them when doing a binary comparison but damned if I know what the differences mean). Anyone else noticed anything like this? Or maybe post some your readings.
Forgot to mention I have the fans running at 36% while idle and that the first card's fans were pretty quiet, but the second and third cards have some pretty loud fans that seem to quiet down somewhat with time.
gpu tdp%: 10%
gpu vrm temp: ~39C
gpu vrm power: ~10W
gpu tdp%: 10%
gpu vrm temp: 30C
