**Relevant PC specs**
CPU: Intel 2600k (OC to 4.5ghz)
MOBO: Gigabyte g1.Sniper 2
GPU: Gigabyte GTX 580 Superoverclock x 2 (SLI)
PSU: Corsair 1050HX
Hi everyone!
Problem: Since day of purchase I have been having some difficulty with this computer. As the thread states, there is an audible clicking noise that can be heard over all computer parts and well outside the case.
Vysnc disabled, there is a high pitch squeeling noise. With vysnc enabled the noise changes to a fast clicking noise. The only way I can think of describing this sound is liken to how you would use your tongue to make the sound of a machine gun firing constantly.
Please note, these sounds only occur when GPU are under load.
Testing: My first assumption was that the sound was being produced by the GPU's through coil whine / capictors. I tested each GPU individually, they both produced the same sounds. I had to RMA one of the GPU's because of a loose fan bearing; I was sent a new replacement card of the same model, this GPU also produced the same noise when under load.
My brother has the same setup as me, except he has two 6950's. His computer also produced the same clicking noise but only more louder. Due to warranty I am unwilling to open the case and part of warranty the place of purchase can inspect the parts. The technician found that the PSU was responsible and has now been RMA'd.
Back to my computer; the technician's summary made me started to think it had something to do with the PSU and perhaps the GPU's were not producing the sound. So I removed the GTX 580's and installed my previous card, a GTX 275. With vysnc on/off the GPU did not produce any audible sound from afar. By placing my ear next to the GPU, a very faint buzzing noise same as my GTX 580's would produce was there but again, it was barely audible.
I went further with the testing by taking out the PSU from the case and placing at a distance far enough to be distinctively audible from other computer parts. I reinstalled the GTX 580's and ran a game, the PSU was making the exact same clicking noise as the GPU's. With vysnc off, the high pitched squeeling noise was also present on both the PSU and the GPU's.
In summary, whatever clicking / squeeling noise being produced by the GPU's was also occuring on the PSU; although somewhat fainter but still very much audible.
I have since replaced the PSU with a silverstone strider 1200w gold, which has capacitors inside the PCIe cables to help reduce 'buzzing' noises from high end GPUs. But...again still the same sound. I'm not sure if this was present previously, but every so often I can hear small intervals of an electrical hum from as far as I can tell, the GPUs even when the computer is idle.
I'm more concerned now of the electrical humming, happens also when scrolling through internet explorer or even Images saved on this computer.
Has anyone had this issue before? Gigabyte have a horrendous RMA process (from experience) so I am abit wary to do so. My main concern is the possible damage to any components in the computer, if this 'electrical buzzing' can reduce the lifetime of the GPU / PSU then I would definately RMA it. Thoughts?
Thankyou, I apologise for the amount of text. Any help provided will be much appreciated!
Kind regards,
Mike.M
PSU: Corsair 1050HX
Hi everyone!
Kind regards,
Mike.M
