GTX 260
PSU GURU
Can I play games from 2005-2010 on a 1GB GTX 260, at 720p? On Ultra
Games such as:
MW2
Rage
Viva Pinata
Depends on the rest of your setup and what resolution you are playing at.
And:
2GB DDR2 800 (2x1GB) G.SKILL
2.4GHz C2D
400GB SATA HDD 7200RPM, SAMSUNG
I'm assuming that's the Q6600. MW2 would be flawless but Rage would lag unless you ran at 720p instead. Tried with a GTX260 recently.
Yep. This is (going to be) my secondary system. I am running it a 720p..... I just checked the monitor specs. Updated post.
It will run most UE3 games just fine. Same games mine started to struggle with (AMD 965, Vista 64bit/Win 7 64bit, 4GB/8GB RAM, 1680x1050):
Crysis 2 - (30-40 average, obviously no HD textures or DX 11)
Crysis 1/Warhead - Mostly smooth, though some parts of the game would drop into the 20s or even below.
BF3 - Medium settings are 30-40 frame rates.
Metro 2033 - Ran well in most areas, though dropped into the 20s or lower in certain parts. Obviously, no DX 11.
ArmA 2 - Low-medium settings. Frame rates from 15-50 depending on terrain.
The card is getting a bit dated.
I'm using it as a secondary machine for if a friend or somebody comes over, we can both play
"Here play on the slow^H^H^H^Hsecondary machine so I can frag^H^H^H^Henjoy playing against you!"
