grounded motherboard?
ChingChang
A friend told me the motherboard had to be grounded through the motherboard mounts (since the case is grounded through the PSU), but I've been running my system fine without grounded mobo mounts. It is a wooden case, so the case isn't grounded, but I could ground the mounts if needed. And I always thought the motherboard was grounded through the PSU - the black wires.
as long as the psu is grounded the mobo will be grounded, the stand-offs are not for grounding anyway, its to keep the mobo from shorting out against the metal case
It is true that those normally are grounds, but are they needed? Not really. Having a common ground to the case is good for protecting against ESD (static) but as you already know the ATX cable provides the ground from the PSU needed by the MB to run.
==>Lazn
