Grey horizontal lines....?
I have two grey horizontal lines running across my screen, basically ones at the top and the other is at the bottom. I just built my pc last week and everything is brand new. If anyone can advise as to what the problem might be it would be helpful.
Thank you. :)
MSI K8N Neo2 Platinum (MS-7025) BIOS v1.2
Athlon 64 3500+
1GB Corsair XMS PC3200XLPRO (2.5-3-3-6 @ 2.8v)
BFG 6800 GT OC
ANTEC Truepower 550W
36.6 GB Raptor WD SATA
200 GB WD SATA
Pioneer DVR-108
19" NEC CRT FE991SB
You wouldn't be referring to the two horizontal lines that always accompany an Aperture Grille CRT monitor would you? Aperture Grille monitors have two black lines that run horizontally about 1/3 from the top and bottom.
lookin at his sig,
i'm guessin that's it.
it's normal. i'm surprised that your monitor didn't come with the warning.
because when i got my trintron it came with this big old poster of how there are two lines
and that their normal, and not to call tech support or w/e.
