edifyingkarma
- Mar 8, 2008
I am running 2x8800GTs in SLI and would like to turn the fan speed up to about 70% to have them run cooler on a regular basis. My only worry is that running the stock fans at higher speeds all the time will cause them to fail sooner.
From experience, have any of you had issues with stock fans failing considerable sooner because you ran them at higher speeds? Thanks for the input
