GPU cooled what to do with memory?
KCompany
I will be cooling my twin BFG 6800 OC with two danger den M4G's.....my guestion is what will be the best way to cool the ram on the card? I was looking at OCZ remsinks and they have a sticker type adhesive is this the best salution?
use those on my x800xt and they work well. The ram shouldnt get hot enough to really justify active cooling, but if you want to go all out, get some ramsinks and then mount an 80mm fan on the end of the videocard to cool them
Yep, what BigTaf said. From my experience, you just don't gain much of a benefit from cooling ram, they don't get hot enough anyway. Actively cooled the ram on my x800pro and didn't notice a difference, even after volt modd. Ram just doesn't require the cooling cpu/gpu's need.
