Got quick question regarding Ultra micro-fly
troisanh
Might sound strange but have a quick question regarding spacers that came with the accessories package case. Are these spacers to be used between the motherboard and pull out tray? ie to isolate grounding? Thanks for the helps guys/gals.
Little red spacers? If that's what you mean, it's to keep the heads of the screws from touching nearby components on piece of shit motherboards.
If your motherboard has large "blank" areas around the mounting holes, then you'll be fine without the speacers.
