Got new Mobo, system wont post...
Quagmire02
I recently swapped out my Asus A8V with an A8N motherboard and a new 6600GT card. I ghosted my boot drive (a partitioned C drive) onto my D so that I could just reinstall windows if needed. Problem is, when I turn my PC on, I get nothing for a display. No post, no boot, nothing!
This is what I have:
Asus A8N SLI mobo
1gb Mushkin memory (2x512)
Athalon 64 3000+ Cpu
Antec 350W PSU
evga 6600GT gpu
m-audio sound card
d-link wireless pci card
maxtor diamondmax ide 250 gb hard drive
plextore 712sa sata dvd burner
So, all this stuff minus the mobo and video card worked on my other system (an Asus A8V and radeon 9600pro). What I see is that i get power, my mouse lights up, my cpu fan spins, my gpu fan spins, my computer makes noise EXCEPT for the PC Speaker and all the general LEDs like HDD, Power, PC Speaker, ETC. Nothing there, no bleeps or bloops from the PC speaker...no display on my monitor...no lights lighting up my keyboard. I know i connected my LED jumpers right...it'd be tough to mess up. I reset my CMOS battery. I don't know what to do at this point. Any suggestions???
Thanks in advance.
Try booting up with one stick of ram only just to set the bios, once you get the settings set up then shut down and throw in the other stick. Happened to my mobo too. If that doesnt work try using another stick of complete opposite ram.
I'll give it a try, but how does one explain the lack of PC speaker beeps and lights? My drives light up (as they should since they are separate) but I get nothing on my front LEDs or my Keyboard LEDs.
I will try the RAM thing when i get home from work, but I'd love more suggestions...
I might also add that Im using a 20 pin PSU and the board has a 24 pin connector. I have nothing plugged into the remaining 4 holes...
id be looking at a possible p/supply problem .not enough.i believe the board need at least a 400 min and a 24 pin to run properly.sounds like there mite not be enough power to go around.350s kinda small for a nf4 board.
