Good to keep motherboard inside box while installing components?
CDdude55
Is it better to keep the motherboard inside the box while installing components (like video card and CPU)? Or take the motherboard out and then start installing the other components?
You should install the video card when it is in the case, the video card hangs lower because of the bracket in the back and will lift out of the slot if you put it on a flat surface.
It doesn't really matter too much. You can leave it in the box, put it on top of the box, or just put it on any clean, flat surface (like a wooden table). But as the person above me said, you should install your video card after you've mounted the Mobo on the case. Install the CPU, CPU fan, and RAM before mounting, and the videocard and various connectors (PSU connections, Hard drive cable, etc.) after mounting.
Thanks for all the help:). And should i also put the anti static bag under it so i will be protected from any static?
you could but I've never had a problem with the motherboard getting static from sitting on the case or a wooden table. The main source of static will be you depending on what your wearing. Just remember to touch something metal or the psu to discharge any potential static before you start working.
Yes, table is good. Put it on top of the motherboard box if you want. Perfect size :).
The way I did mine was to install everything outside the case on a table just to make sure everything works and I installed the heatsink correctly. Then I put all my drives, fans, psu into the case. Ran most of my wires the way I wanted it and then dropped in my motherboard with the proc, heatsink, ram installed. Plugged in my pci/pcie cards and was on my way.
Install the psu and plug in the power cable but leave the switch on the psu OFF on the back. Then everytime you touch the case you ground yourself.
Clean your table of dust etc before you use it also. Don't shuffle across your carpet with bare feet, wearing fleece pants and then try to install you proc also.
Thanks alot for the info!:) will help me alot!
- - I'dplace it on the anti-static bag it came with - -
Actually, the bag only protects whats inside of it; and the outside of it could be conductive (if its metallic -- this is a bad thing). So no, don't put it on the bag. Put it on top of the box, assuming it isnt a metallic box, and you could also test the vidcard on there by letting the bracket hang over the edge of the box.
So just put the motherboard on its box without anything elso under it? and do you have any grounding tips?
I usually put the motherboard on top of the box it came with, then install RAM and CPU. Sometimes I put the video card in and connect the hard drive and set up OS just to test to make sure everything is working before I put it in the case and spend all that time hiding cables and crap.
that won't help. Motherboard would have to be inside anti static bag for it to do anything.
These bags are basically faraday cages which is metal and designed to conduct electricity and protect whatever is inside of it (not on top). So it does make sense that if you were to power up a motherboard on top of a faraday cage, it would short out from the pins on the back touching the metal. But I have never seen this happen and I don't think it's even possible for anti static bags to do that.
A good way to prevent ESD is to connect the power supply to the motherboard and to the wall. If you turn the switch off on the power supply, that completely cuts off the power, but it still keeps the motherboard grounded. And also every couple mins you should be grounding yourself by either touching a non painted area of the case, or ust touching your power supply if it is connected to the wall.
I put it on top of a box and just off the edge, so the video card bracket thing doesn't mis-align the video card.
But you can still be grounded if you don't plug in the power supply and touch it to be grounded right?
How? because your feet are touching the "ground" ? hehe... no, it has to be plugged in. There has to be something connected to the proper ground.
