Good Fan Controllers?
Raytheon
I have a P180B and I want to replace the Antec Tricools with either the Scythe Slipstreams or the 100CFM Silverstones. I heard that blowing at full CFM, those would be pretty loud so I was looking at some fan controllers and stumbled upon this.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811999046
It's perfect for controlling three fans and it fits in a 3.5" bay. Is there anything I should be concerned about with the fans or the fan controller, or installing?
Your choice is a very good one. Its capable of feeding each fan 12watts which is pretty much tha max that desk top fans require so you wont run ito any voltage problems. Just make sure to always check the supplied wattage per channel when shopping for a fan controller.
The scyth master is a great one with excellent build quality, but i think that the op was looking for one to fit in a 3.5" bay.
