Erasmus354 said:I'd bet that block performs like a four pronged pile of cow dung...would kill flows and think of all the y connectors you would need as well.
Erasmus354 said:I'd like to point out that that site has not been updated in 2 years...like the time of the maze 4 or maze 3. There has been quite an improvement in watercooling blocks since then....also that waterblock is very unique and was designed to work in his watercooling system, which is very cool, but is a very low flow system. I wouldn't recommend that design unless you are doing something very similar to him. (Keep in mind that he was cooling a GF3 as his GPU, so nothing besides the cpu really needed much cooling)
Also...autodesk inventor rules![]()
CAD OC'er said:ummm that cpu block was published on 4-28-2004 so it was more like 8 months ago.
Porn_Star said:im considering building this block because it is pretty... the block that i am designing is going to be quite a bit larger than his too.. and if i decide that i dont like it ill just go and get one of the swiftech 6002's
