TheMasterRat
- Jan 28, 2001
Ok, here's the scoop.
Original system = Soyo K7V Dragon+ Motherboard w/ XP1900+ CPU
New system = Asus NF7S ( or is it the abit? bah, doesn't matter. Nforce chipset) w/ Barton 2500+
All drives remain the same, as does the video card.
Obviously the original installation now boots to a STOP 0x7B, failing to read the hard drive successfully ( because windows is lame like that and won't default to a basic ide driver)
I have tried running an in-place upgrade on the installation and this did not work.
I now have a parallel on another partition that boots fine.
I want to find a way to get the original installation booting. I'm 99.9% sure it's possible, but I need some ideas.
Things tried already :
Services key transplant (From working install to failed install) <-- Still STOP 0x7B
Transplanting the entire CurrentControlSet key from working install to original installation (Going through and changing any paths to reflect what it would be in the original)
This gets me to a desktop, for about 2.6 seconds but this error is displayed :
System error lsass.exe:
When trying to update a password the return status indicates that the value provided as the current password is not correct.
Then the system restarts.
I think I tried just transplanting the services key and the enum key, but that I don't remember 1. If I actually did it and 2. What the results were.
Any ideas other than rebuilding the entire system?
