Gigabyte questions
darkeen
A few questions about gigabyte boards.
1. Are they reliable/well made?
2. What is there DPS?
3. Would a zalman-7000cu fit on this board?
Just got this board today so,
1.Yes
2.Dual Power System-Gold is an onboard six phose power circuit aimed at providing a more durable and stable power circuit to the cpu for increased system stability.
3.Are you asking if it will fit with an A64?
Well it looks like the dps might get in the way of mounting the 7000 I was just wondering, thanks for the help btw.
Well, I have a ThermalRight SLK-947U that sits perfectly between the DPS card and caps on my 8KNXP.... I would think that the rise that the Zalman gives would let you clear that DPS module on that one.
