KaminaAyato
- Feb 18, 2004
I'm using the older KT400 Motherboard from Gigabyte (GA-7VAX) with an AMD 2400+ Cpu on it. Anyways everything is running fine with the CPU idle temp of 31'C, and load temp of 33'C so I decided to take advantage of EasyTune 4 from one of the cd's provided by Gigabyte. I intstalled the program, and "overclocked" it to 2250 MHz, the only thing is that Windows XP doesnt recognize it running at 2250 MHz, and there is no difference if I play games with it (Halo, GTA: VC). I was just wondering if EasyTune actually works, and that if it does indeed work... How well does it?
Thanks
-Nick
Thanks
-Nick
