Gigabyte 8IK1100 Won't Post
Anjeon
My PC had been working fine with this MB for several months now. When I turned it on this afternoon, it would not post. No beeps and the screen stays off. All fans and drives power up, and the memory LED is on (amber.) I removed all PCI cards, disconnected all drives, and any extras like USB/Firewire connectors, no change. I tried each stick of RAM individually and in different slots, no change. I tried a different video card, no change. I removed and reinstalled the CPU, no change. Finally, I took everything apart and rebuilt the machine, still no change.
I don't have an extra CPU or power supply to test with. How can I tell what the problem is, and what can I do about it?
can you hear any beeps when you try to power up? I'm not familiar with that board, and I'm at work on a dialup connection, the manual is too big to download here to look the beep codes up. Can you get your hands on a multimeter and measure the output of your power supply, especially the orange wires on the ATX plug, the +3.3 volt line. I'm leaning towards a power supply that is missing a voltage, I had one fail like that on me a year or so ago, and it refused to boot but the fans would spin. Good luck.
Being a Gigabyte, does it have "dual bios?" If so, switch to the backup BIOS and see if you can boot. If that works, be sure to repair the main BIOS.
==>Lazn
Try to borrow a psu or processor from someone.. both of those could easily cause it.
i had this happin on my 8iK1100... in fact alot of times..but it only happined after [H] overclocks.. all you need to do is take out the power cable and the one from the board..and take out the battery...and wait about 20sec...then put it all back in..and it will ggo back to defualts and oyu will have to redue your BIOS.
There are beep codes listed in the manual, but it doesn't make any beeps. Not even the single beep it normally does when turned on.
It has dual BIOS but I don't know how to swap them except through the graphical menus when turned on, which don't come up. I looked at the diagram for the board and there's no jumper listed to swap BIOS.
I took the CMOS battery out for a while but that didn't help either. It's never been overclocked.
I hope to test the power supply tonight. I'd be pretty disappointed if this Antec only lasted 4 months.
did you take the battery out and EVERY THING POWER on the board..you got to unplug the power cord for the motharboard and the PSU...cause the computer needs to clear the BIOS..and if its getting power..it cant reset...its still holding on to the old bad BIOS
i was wondering if you can hear it boot up maybe..like as if it was going into Windows...caus ethen the video card would have gone out....
I unplugged everything before I messed with stuff inside. Once the HD spins up it stays quiet, no sounds of reading. I took it in to some place to test out the CPU and MB. Thank you all for the suggestions.
Had this happen with my 8ik1100 as well about 2 months ago. Just one day, turned it on and nothing, no post, no beeps, nothing. Tested CPU on another machine and it was fine. Wound up sending the motherboard off for repair/replacement. Got it back a couple weeks ago... well it's a new board anyway. I can only assume that this isnt an uncommon problem with this motherboard, maybe a batch of them got bit by that bad capacitor problem? Dunno.
Bought a p4p800se while waiting, and am just using that still instead of swapping back the gigabyte board... cant decide if it's worth the trouble lol.
i still have my 8iK1100..about to put it in commision too....i believe its a great board...
now if only i can find that CD.... :rolleyes:
