Get a regular router, flash it with DD-WRT, and get a gigabit switch. Connect switch to one of the router ports and you're gold.
And the Internet connection and wireless connections are all far less than 100Mb. No problem here.But then said gigabit switch is going to a Fast Ethernet port on the router. While most LAN communication could probably be done through the switch, a gigabit router would be better I believe.
What is the cheapest I can get away with for pci 802.11n cards that actually work well? It's sort of expensive when you need 3 or 4 of them and the name brands are $90ish a pop.
