OK check my 'math' on what I want to do and to find the easiest way of doing so.
Here is what I'm working with.
Pentium 4 dinosaur
is my on ALL the time torrent PC, it does what i need it to while using minimal power etc etc
and
THE RIG!!!!
the i-7 920, 12G DDR3 ram, Asus P6T6 mobo...etc
This is where I store everything. I have 4 TB of space at this time.
The problem I run into is this.
The P4 does not have USB2, and either way I use network transfer between the two PC's to get the data onto 'THE RIG'
'The Rig' ASUS P6T6WS Revolution Mother board has 2 onboard Gigabit Ethernet Ports.
THE GOAL IS TO MAXIMIZE DATA TRANSFER SPEEDS BETWEEN THE TWO COMPUTERS
At this point in time speeds are around 10.8MB/s....which sucks as most of the time I transfer around 50 Gigs at a time which takes around an hour.
THE PLAN
1)Buy a Gigabit Ethernet Adapter PCI-e card and install it in the P4 machine.
they seem cheap like 30 bucks
2)Buy a Gigabit direct connection patch cable and go out of my second Gigabit port on 'THE RIG' and into the new Gigabit Ethernet Adapter PCI-e style card.
I need to make sure I'm not going about this wrong.
The alternative is to get a gigabit pci-e card, a gigabit hub and gigabit cables.
Thanks for your insight all...letting me know I'm not doing this all wrong
D A N N Y
Pentium 4 dinosaur
and
THE RIG!!!!
THE PLAN
D A N N Y
