I'm building a small file server for our office (4 client machines). Content will be mostly larger files, so I want to max out network transfer speed, especially since the clients have 1Gig connections themselves. I've built a few machines, but this is my first server. So I have a couple of newbie questions:
1) I've read on this board that in order to max out a GBit connection, the on-board network chip must not connect over the PCI-Bus, but directly to the Northbridge.
How do I find out? I have browsed the webpages of some manufacturers (Asus, Gigabyte), but could find no tech spec that stated how the network controller is connected. Is there a specific term for this I have to look for?
I also assume that this means that all stand-alone GBit cards for PCI suffer from the same drawback, and I have to go on-board. Is that correct?
2) Some boards have dual GBit ports. Is this only for router/firewall/redundancy reasons, or is it somehow possible to use both at the same time, and double the total bandwith?
