Getting some crazy temperature readings
EnderW
I was checking the temps on my WHS last night and noticed some crazy numbers.
I shut it down and felt the Seagate drives and they were pretty cool to the touch, obviously nothing like the crazy numbers that were showing.
Any ideas on what is causing the reported temperatures to be so high?
They were normal when I finished the machine a few weeks ago.
Specs
Antec Solo
Supermicro CSE-M35T-1B with Scythe KAMA FLEX Fan SA0925FDB12L
Antec EarthWatts 380W
Gigabyte GA-MA74GM-S2
AMD Athlon X2 BE-2400
Scythe Zipang
Corsair 2 x 1GB DDR2 800MHz TWIN2X2048-6400 G
Syba PCI 4 x SATA controller card SD-SATA-4P
6 x Western Digital Caviar Green 1TB WD10EACS
4 x Seagate Barracuda 7200.11 1.5TB ST31500341AS
APC Smart UPS SUA1500
Windows Home Server
Thats very strange, what firmware are on those drives? Besides those 2 drives that are gone insane, does disk 9 have good cooling? Because it looks a little toasty compared to your other drives.
I think it's a bug with the real time monitoring. When I turn it off, and manually check the drives, they're all below 40 C.
Maybe a decimal was dropped? 24.3 and 25.2 are reasonable, if theyre well ventilated.
Well since its about 490 degrees Fahrenheit your house should have caught on fire by now.
