Hello all,
I have a few questions, wondering if you expert [H]'ers can help me out. I know, I know, everybody and their mother has a question about overclocking a Core 2 Duo nowadays.
Here's the story:
I recently purchased a C2D e6400 with the intention of overclocking it to 3.2ghz (8x400). Nothing too extreme, just looking for a good bargain. Anyway, the parts came in and the machine works fine. It seems stable enough at 3.2ghz, (no extensive tests yet, just a half an hour of dual instance prime95 torture tests) and I only had to bump the v core up to 1.350 (it started at 1.325, CPU is stepping 6 I think). The temperature right now is idling at apx 50c, and going up to about 70c, depending on which monitoring program you look at.
My questions are:
Do you think that 50 idle and 70 load are acceptable temp ranges? I keep the room at about 80F (I'm from the tropics)
Long term, with using the retail HSF be a bad idea, or should I upgrade to a larger one? If so, what's a good one without getting too fancy? Hey, $50 isn't going to break the bank, but if I don't have to spend it on another heatsink when I've already got one that works, I'd rather spend it on something useful.
...and dear gosh, what is with all these discrepancies between all the temp monitor programs? For reference, I used core temp and speedfan. It can vary up to 10 degrees between the two of them.
Thanks ahead of time!
Art
Here's the story:
My questions are:
Art
