Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
ya current kings are the biostar tforce for 6100 and the foxconn for 6150. hopefully msi has good options, and the upcoming dfi (if they ever get around to releasing it).
yeah, but a review somewhere (i think it was pcstats) said they got 275fsb stable on it. that plus voltage settings + dividers = win. well almost, the biostar still beats it, but if you have a 10x multi the 275 will most likely max out ur cpu, or come close enough to it. if your cpu can do higher, just lower the volts and run cooler, 2.75ghz is plenty!
I have the foxconn 6150 board. I just started to play with it. I have my AMD 4000 up to 2.7, stock is 2.4. I'm still figuring out the bios and learning how to oc an AMD64. So far I'm happy.
