When i atuo detect it says 310/443. Is that 443 doucle b/c of the ddr memory or is it 443? I used the coolbits overclocker so it shows up on my drivers.
Since I have no experience with the specific card, I'll give you the generic answer. Since every card is going to differ drastically from another in terms of how well it overclocks, your only real option is to find the max yourself. Find one max (mem or core) without artifacts, back it down to default, find the other max, and then try to get them both there together. Chances are that wont happen, since its harder on the card, but youll usually be within 10mhz of either max.
damn too late i bought a 5500, all i want to play is steam games(which is the halflife egine) and warcraft III. Those are the only games i play. so i guess it alright.
I heard its a NV34. Is that good i don't know anyting about nvidia. I used to have a 9800pro but i sold it. and i got a cheap video card b/c i gave up gaming.
Dude selling a 9800Pro for a 5500FX thats almost as bad as selling your mother j/k
But after that shock i would just do as sKiTz0 said and inch it up until you find the max.But it should be fine for HL1 and warcraft at least!
