fightingfi
- Oct 9, 2008
The answer is the same as back then. You can't install directly from the disc because SafeDisc DRM no longer works on Windows Vista and later. And you can no longer download the game digitally due to Games for Windows Live being shutdown. Bite the bullet and buy the Ultimate Edition from the Microsoft Store. Saving $4 isn't worth the potential of buying from a shady seller. It's also on Game Pass for PC.
Just out of curiosity I tried it with the disc and it takes some time installing, but it seems to work fine after manually downloading a few of the patches. I got an error upon launching the installer from the disc, it said something about it possibly not working correctly, I clicked on the look for updates button, it installed games for windows marketplace after which it installed from disc, tried to run the game but got an error, after a quick google to see, I downloaded a zip with the 3 patches, ran them in order and managed to get the game running after that.
The game should run fine if you use the last version of the GFWL package so you can still authenticate and use your profile. The issue is getting the game to install. The retail boxed version of the game uses SafeDisc which is supposed to have been one of the legacy DRM schemes that Microsoft stopped supporting, and the marketplace itself is no longer available so you can't download the game anymore. I'm more interested in how you got the game to install than how you got it running.Just out of curiosity I tried it with the disc and it takes some time installing, but it seems to work fine after manually downloading a few of the patches. I got an error upon launching the installer from the disc, it said something about it possibly not working correctly, I clicked on the look for updates button, it installed games for windows marketplace after which it installed from disc, tried to run the game but got an error, after a quick google to see, I downloaded a zip with the 3 patches, ran them in order and managed to get the game running after that.
