Aggravation
- Mar 2, 2006
I just got this display. Out of the box it seemed great, played Battlefield2 and surfed the web for a few hours back and forth...no trouble.
Returned later last night, installed the EzTune software, and FRAPS started playing Battlefield and the display would go dark and then the on screen display feature of the panel would show "No Signal RGB".
Nothing I did could get the panel to recognize the DVI-D input I was using I had to re-boot to get it to recognize the panel. Switched to VGA...same thing, after playing for a few minutes it went dark again.
I tried lower resolutions...no help. It even went dark one time while just surfing the net.
It seems to me this is a problem with the panel itself since I'm not using the RGB connections. I never had a second or third connection plugged into the panel always used the DVI-D except the one time I tried the VGA but never had both plugged in at the same time and never plugged anything into the S video or composite or component (RGB) connectors.
I'm about to try it after un-installing the EzTune software and see if thats the problem then I guess I un-install FRAPS if the EzTune isn't the culprit...
Anyone have any suggestions or experience with a panel suddenly going dark and complaining about "Lost Signal RGB" when you weren't even using a RGB connection?
My system is EVGA 131-K8-NF44-XX mATX SLI mobo using a single BFG 7900GT OC card, AMD X24400+ 2x1gig OCZ DDR400
The case is relatively cool, video card never goes above 52c that I've ever seen
Never had any other problems with this computer, it's only a few weeks old.
Using the approved 84.21 drivers.
Any help would be much appreciated!
