Ok so what they are calling the 2005fpw killer already has a deal. The Best Buy coupon that is 10% any item in the store. Located here : BB Coupon
Now the trick is, and your mileage may vary. When you go up to checkout, they will say the coupon will not work on computer monitors. SO what I did was say, well this is also an LCD TV, which the coupon says any LCD TVs 399 and up. They asked the manager and he was like, well he is right, since I explained that this monitor can be used as a TV and thats what I am using it for. Also on the box itself, it says "HD Ready with DCDi", point this out and say its also an LCD TV and they coupon is good on LCD TVs. BE POLITE and convince the manager, and you walk out with 600- 10% = 540 bux! Worked for me, also a heads up. There isnt a DVI cable in the box, just VGA, so pick one up as well
BTW this monitor is badass
