Gamecube and Samsung 710T
Rabid Yellow Dog
I want to connect my GC to my Samsung 710T (17 inch 12 ms). It only has VGA and DVI inputs so I have to use a converter. Does anyone have experience with a Component to VGA or DVI converter? Lik-Sang has this which looks good but some of the reviews say that it won't work with non-progressive scan games. I don't care whether the GC input is overlayed over the computer's or I have to hit the "source" button, I just really don't want to spend over $50. (When I got my GC I bought a Redant S-Video to VGA box, which works, but it looks terrible and it switches the audio channels. I really want to replace it.) Thanks in advance.
This is what I need: Component Video to VGA converter that can do interlaced and progressive scan. I don't understand why all this stuff has to be so hard. :mad: Help....me.....
edit: Like this, but cheaper.
But then he'll be limited to 320x240 streched, no? Maybe an HD PC tuner?
All the pci tv tuners listed on newegg have composite and s-video inputs. Would the s-video on the tv tuner look any better than the s-video -> vga box that i have now? Spending the money for an HD tuner is ok as I was about getting one. Are there any with Component in?
if you have one of the older GC's with the analog a/v out AND the digital a/v out. You can look around online and get a digital cable for your gc that's a dvi connection. One end goes in the digital a/v out of the GC, and the other end is a dvi connection, goes right into your monitor, bam, your all set :)
if it were only that simple...
LikSang said:
I'm interested in buying this cable so I can connect a VGA-monitor or TFT LCD to my Gamecube, but what sort of connector is it? D-Sub, DVI or something else? Can somebody enlighten me here please? :)
[admin: This is NOT to connect the Cube to VGA, it is for use with equipment that have Japanese D-Input Terminals]
the new ones dont have the digital out?
that sucks!
oh damn, that sucks man. I just assujmed it was dvi, or least vga. Well that's why i bought the component one for the gc, to connect to my hdtv and get progressive scan :)
the hdtv tuners out there do not have hd capture. in order to get a board capable of hd capture, you have to spend alot of money (at least $2000). look to canopus' website and you'll see what i mean
wait but that isnt true, i just read about some card recently that'll do hd capture and its only like 150 bucks i wish i could find it again but i was just googling around so anyone should be able to find it
ATI HDTV wonder maybe?
no it wasnt that one because apparently it has some problem with some spacific standard or something (sorry i dont know more about HD, havent been able to afford it so dont know a whole lot) but yeah there are certainly cards out there that can record hd content for well under 1000
a viewsonic n6 will do the trick. but it may be more expensive than what you want. it's $170.
you could look into a vdigi vd-z3
aren't vga and component basically the same idea? (red, green, and blue each on a differnt wire for maximum picture quality) if so, why is it so hard to convert one to the other, and why have different standards in the first place?
i found this site and it looks like capture cards with component inputs are rare and expensive (>$500)
does somebody have a screenshot of what a console looks like hooked up through the s-video port on a tv tuner card or capture card? this seems like the best solution; i just don't want to buy anything without knowing it will be better than what i have already.
Dude you need this..you can thank me later:
http://www2.newegg.com/Product/Product.asp?Item=N82E16815116003
This is wayyyy better than using a TV tuner. Picture is flawless. I have used a ATI VE and Winfast deluxe TV Tuner and nothing comes this close. Heck it is identical to my 27" WEGA
but...but...$180!??!?! I understand that it is better (when its that expensive it better be better), but playing my GC is the only reason I need a product like this. I was intending to get an HDTV tuner anyway, and if the s-video quality is good through that, that is what I'll be doing. If you bought me the viewsonice thingamajigger, I would be thanking you later. :)
Can anybody recommend a good HDTV tuner?
