deviation56
- Jun 3, 2005
Ever since I recently formatted, I've been having tons of problems with my computer, mainly game related problems as follows:
Half Life 2 - Crashes as soon as it starts saying there's an error with HL2, the game still starts leaving the error in the background and is playable for about 5-10 minutes then it will exit crash to desktop.
UT2004 - The FPS will start out fine around 70 and then will slowly continue to drop for about 5 minutes until its about 2-3fps and unplayable.
Command and Conquer: Generals - Works fine for about 10-15 minutes then crashes to the desktop with an error stating that I either have a virus(nope, just formatted), my hardware is inadequate(obviously not), or my hardware is overheating.
Need for Speed Underground 2 - No apparent crashes yet.
System Specs as follows:
500w Aspire Power Supply
MSI K8N Neo Platinum Motherboard
AMD Athlon 64 3200+ Clawhammer-CG CPU (OC: 2.2ghz)
1GB (512MBx2) Corsair XMS PC3200C2 DDRAM (2.5-3-3-6)
HIS ATI Radeon 9800 Pro Excalibur IceQ 128MB Video Card (OC: 412/365)
120GB Seagate Serial-ATA Hard Drive
I was pretty convinced it was a driver problem seeing as I just formatted and everthing was working fine prior to format so I tried installing older drivers (catalyst 5.4 and 5.3) and there's still problems. So tomorrow I'm going to try putting in an older Nvidia video card and I'm also thinking about getting rid of the SATA drive just because its constantly getting corrupt and crashing... but any other ideas as to what might be wrong?
thanks
thanks
