Gainward 6800gt GS DVI problem
conflix
When trying to hook up dual monitors using the second dvi port, the card won't display the monitor. In the graphics card options it will show that the "xxx" monitor is connected, but it acts as if there is no signal being sent. However, I can get the second monitor to display if I use a vga cable with the dvi adapter. This is the only method that I could get to work. I read on the gainward UK forums that a couple of people were having problems as well, but still no solution. Any thoughts?
Came too late... Had the same monitor problem last August when bought my Gainward card.
