fUnc pad + teflon tape.
SVTLightning
Anyone know where I can order these from the same sight? Only really want to pay for shipping once :)
BTW, who has a fUnc pad and do you like it? I'm going from a worn out ratpadz (first one) and want to try something different.
NM, ordered fUnc pad from newegg and teflon tape from performance-pcs.com. Hope it's as good as my ratpadz was.
I've been using an X trac HS for the past year and noticed the abuse I gave the upper left corner. It's smooth whereas the rest of the pad has a fine texture to it. I'd love a new one, anyone else got some recommendations?
My RatzPad just wore out too and i'm thinking about getting a FuncPad. What are your oppinions about the FuncPad? Especially how it compares to RatPadz
Oooooohhhhh....the prettty pads....
Well, my new mx700 seems to be tracking a hell of a lot better than my intellimouse explorer 3.0. To be fair my ie mouse doesn't track at all any more :( The pads on the mouse look exactly like my ie mouse, but instead of sticking to the pad, they glide like teflon tape!?!?! I'll probably order some skatez or wax when the pads do wear out. For now, I'd like a nice pad that keeps cool, like the icemat. Tho I don't know if that would track well...
fUnc pads OWN! As I recall they are covered with 100% teflon and are much better quality then anything else out there. 2 of my friends converted from their ratpadz and would never go back.
I have 2 of these and I have to agree they are a great mousepad, though I havnt used a ratpad.
They do wear out though, after about a year the smooth side was pretty scuffed up and my mice just didnt glide on it like they used to. No problem though, these things are 2 sided, just flip the plastic part and the other side is good to go. I also found the textured side to be even more slick than the smooth side.
so its good for another year or so.
all in all, great gaming surface.
Haha! My xtrac hs wore down after a year too, but the flip side tracks not so well :( I'm thinkin' about the xtrac ripper with all it's 11in x 17in glory, woot!
http://www.xtracpads.com/ripper.htm
I have an Xtrac that I won at a LAN party, they are nice pads, but they arent that good for LANing becasue they tend to get beat up when being transported, the sides of mine are peeling up...GRRR...
if you are going to leave it at home I recommend this pad as well.
If i remember right.. fUnc pads come with a handy steal case for transporting.
