recently, i was getting dx9 errors, the same problem i've had 3x in the past, so i go about reinstalling dx9 like i did... 3x before. i used the dx 8.1 installler, and then run the DX9 installer, problem fixed. i have also done this on many other computers other than my own, and it has always worked.
after trying this, i found that you cannot do this when SP2 is installed. when i went to reinstall dx9, it says its installed, and after some searching around google, i found that sp2 does not allow you to do this. i backed up C, uninstalle sp2 and now windows and safemode wont boot, i've heard that you aren't supposed to uninstall sp2(b/c of the headache if it doesn't work), but this is what many websites said to do for reinstalling dx9 on a SP2 machine. i tried restoring drive C (appears drive D in the computer i put the drive in to restore C) and nothing... any suggestions?
i just don't want to have to reconfigure everything, i keep all my other non-OS files on other drives, but its a pain to reinstall a few dozen gigs of programs and reconfiguring xp the way i had it before. from the backed up C drive, is there a way i can get the registry, drivers ect...?
