FSB Question
rwh1957
I've heard someone say that if you make out the memory on a motherboard. It will lower your FSB. Does anyone know if this is true or not. Thanks for all replies
maxing out the memory that the motherboard can handle. If the MB can handle 3gigs of memory. Then you put 3gigs of memory on the MB. I was wondering if the amount of memory on the MB affects the FSB in any way. Thanks for all replies
thx for the clarification...
no, it shouldnt affect fsb but if it does its probobly because of a bug in the bios.
