FS: Closet Cleaning Sale, Various PC Parts, don't be afraid to make offers!
Discussion in 'For Sale / Trade' started by Emission, May 11, 2018.
  1. Emission
    Emission 2[H]4U
    4,034
    Dec 6, 2005
    Hi everyone, moving out of my current place soon and need to lighten the load a bit. Everything ships FedEx/USPS, all items OBO, shipping included unless otherwise specified. Paypal accepted. Heatware at Emission. Everything can optionally be picked up locally by Union NJ. Open to combo offers, saves me on shipping.
    Pictures
    IMG_0378.jpg IMG_0380.jpg IMG_0407.jpg IMG_0408.jpg IMG_0409.jpg IMG_0411.jpg IMG_0412.jpg
    Received my ESD bags!
    Motherboards
    ASRock AM1B-ITX
    - Bundled with Sempron A8-3850 CPU
    - Comes with I/O Shield and CPU above.
    $45
    CPUs
    Intel Core i5 2500K
    - Ran in a P8H67-M PRO at 106 MHz BCLK and stock multipliers with excellent results, never overclocked otherwise.
    $40
    Intel Core 2 Duo E8400
    - Think I had it up to around 3.8 GHz on a terrible nForce chipset board.
    $5 + shipping
    RAM
    Corsair CMZ16GX3M4X1600C9G
    - DDR3 1600 C9, 4x4GB Kit, Matte Gold Heatspreaders
    $75
    G.Skill F3-12800CL9Q-16GBXL
    - DDR3 1600 C9, 4x4GB Kit, Red Heatspreaders
    $75
    Patriot (?) DDR3 1333 8GB
    - DDR3 1333, 2x4GB Kit, no stickers so I can't confirm model but I confirmed speed and capacity inside the BIOS of the ASRock board above. It was being used in that system without issues.
    $35
    Samsung 4GB DDR3-1066 SODIMM Kit
    - 2x2GB kit
    $5 + shipping
    Samsung 2GB DDR3-1333 SODIMM
    - Single 2GB Stick
    $3 + shipping
    Hynix 2GB DDR3-1333 SODIMM
    - Single 2GB Stick
    $3 + shipping
    GPUs
    VisionTek HD 6670 1GB GDDR5 Low-Profile PCI-E 16x
    - Visiontek 66701GHK
    - Comes with a full-profile PCI bracket. May have a half-profile laying around.
    $30
    PSUs
    Antec EarthWatts 380W
    - Antec EA-380
    $20 + shipping
    Rosewill RD400-2DB 400W
    - Looks like an APEX SL-8400BTX in Rosewill clothing.
    $20 + shipping
    SPI 350W
    - Sparkle / FSP FSP350-50GMN
    $15 + shipping
    Cases
    - Local pick-up preferable on these, some of them are pretty heavy. Will gladly ship if you want to pay for it. Only come with screws necessary to hold in accessories or mount doors.
    BitFenix Prodigy - ITX
    - Might be missing some of the interior panels/accessories, has some scuffs here and there. Lost the original PSU mount bracket so bought a Lian-Li bracket that fits pretty closely. Should have all the front panel wiring and exterior panels at a minimum.
    $25 + shipping
    Lian-Li PC-C37 - mATX
    - Slim profile Aluminum HTPC Case, light scratches on the top panel and possibly the sides, front appears clean, comes with 1x 5.25" external and 1x 3.5" internal bay mount.
    $25 + shipping
    Tuniq Tower - ATX
    - Ancient old-school ATX tower with the cheesy lighting and front door. All accessories intact.
    $20 + shipping
    Monitors
    - May have an extra VGA cable if you need it for either of the first two.
    Acer X223W bd
    - 22" 1680x1050 Monitor w/ DVI and VGA inputs. Comes with power and DVI cable.
    $45 + shipping
    Insignia NS-20EM50A13
    - 20" 1600x900 LED Monitor w/ DVI and VGA inputs. Comes with power and DVI cable.
    $40 + shipping
    MAG LT765s
    - Ancient 17" 1280x1024 LCD Monitor w/ VGA and Speaker inputs. Comes with VGA cable and power adapter.
    $20 + shipping
    Watercooling
    EK FC750 GTX Acetal GPU Waterblock
    - Should fit most if not all reference Nvidia GTX 750/750Ti's, and some cards with the same bolt hole pattern assuming other board components clear and the GPU die sits at the right height. Had this mounted to the VisionTek HD 6670 at one point for funsies. Block only, comes with screws, DRAM pads, thread block adapter and 2 stoppers.
    $30
    Swiftech MCP655 Non-PWM D5-style Pump
    - Pump and mounting bracket only, 1/2 ID barbs.
    $40
    Swiftech MCP600 Pump
    - Ancient pump that still runs like a champ, does vibrate a bit but it's been sitting in a box for most of the time I've owned it. Pump only, 1/2 ID barbs.
    $20
    Alphacool NexXxos XT45 180x180mm Radiator
    - Great shape, few if any bent fins. Fits the Silverstone 180mm fans listed below.
    - G1/4 Threaded, 6x in/out and 1x fill ports.
    $45
    EK-UNI Pump Bracket
    - For mounting an EK pump mount / res mount to a 120mm fan or fan mounting holes.
    $5 + shipping
    Corsair H80 Radiator w/ Tubing
    - Basically came off of a H80 kit where the pump died. Was going to figure out a use for it in an open loop. Tubing cut-off where the pump end used to be. Radiator + original tubing only. Thick rubber-style tubing, 1/4 ID?
    $10 + shipping
    - Fittings might have scuffs/scratches from typical use.
    Assorted Bitspower Fatboy Barbs G1/4 1/2 OD
    - 6x Black
    - 2x Bronze
    - 2x Chrome
    $2 each + shipping
    Assorted G1/4 Extensions, Fill-ports, stoppers
    Bitspower Fill-port
    $5 + shipping
    Extensions
    $3 each + shipping
    G1/4 Male to G1/4 Male coupler
    $2 + shipping
    Stoppers
    $1.50 each + shipping
    Assorted Primochill 1/2 ID 3/4 OD Colored Tubing
    - Assorted lengths of Dark Blue, Bright Green and Bright Red translucent tubing. I believe all of it is UV reactive. Easily 20+ feet worth.
    $25 takes all of it.
    Swiftech pre-mix, 1L
    - Distilled water + Swiftech's anti-corrosion/growth and lubricant additive.
    $10 + shipping
    Fans
    - Literally have an assortment of everything. Some fans might have old/worn bearings, definitely can't test them all so YMMV. Will at least come cleaned of dust. Will also need to get pics of this.
    80/120/140mm Corsair, Silverstone, Fractal Design, etc.
    - 3 and 4 pin.
    $3 each + shipping
    Silverstone 180mm Fans
    - AP180/181?, 3 pin. Bearings appear to be in good shape. 2x Black Air Penetrator, 1x White Regular Frame.
    $10 each + shipping
    Miscellaneous
    - Random heatsinks from my box of crap, hard drives, optical drives, adapters, etc.
    Unidentified Zalman 120mm Tower Cooler
    - No mounting hardware, cooler only.
    $10 + shipping
    AMD Ryzen Stock Cooler, 65W
    - I believe this one is the Wraith Stealth, non-LED all aluminum.
    $5 + shipping
    AMD Stock Cooler, 45W?
    - Aluminum clip-on cooler for 754/939/AM1,2,3,4 w/ 70mm Fan
    $5 + shipping
    AMD Stock Cooler, 125W-ish?
    - Copper base w/ copper heatpipe model. Has a Noctua 92mm 4-pin fan strapped to it.
    $12 + shipping
    Intel 115x Cooler, 65-95W?
    - Has the copper insert, believe this is at least 65W. Still has OEM thermal material intact.
    $5 + shipping
    Intel 115x Cooler, 45W
    - Like above but thinner and no copper core.
    $2 + shipping or free w/ other items.
    LG SATA 12X BD-ROM/DVD-RW
    - UH12NS29
    $40
    Trendnet TEW-623PI PCI Wireless N Adapter
    - 3x Antenna Connections, comes with external cabled antenna box with magnets/wall mount holes.
    $10 + shipping
    Linksys WRT54G v5 Wireless Router
    - Powers on, comes with power adapter.
    $5 + shipping
    Seagate 7200RPM 250GB SATA HDD
    - Bare drive.
    $5 + shipping
    WD 7200RPM 250GB SATA HDD
    - Bare drive.
    $5 + shipping
    Sandisk SSD Plus 120GB
    - Used very lightly for a couple months.
    $60
    CM Storm Sirus Gaming Headset
    - Headset only, in pretty good shape.
    $20 + shipping
    Razer Blackwidow Ultimate 2013 Mechanical Keyboard
    - RZ03-0038 Model, Blue Backlit keys, Cherry MX Blues. It's seen pretty heavy use, but everything still works.
    $30 + shipping
    Dell XPS 630 HDD Cages w/ Trays
    - Have some of these from old XPS towers I recycled, could probably mod them into another case. 4 individual cages, 2 drives each. They're all stackable, shown in pics as 2x2 stacks.
    $5 each + shipping or $25 shipped for all 4
    Phanteks Enthoo XL ITX Upgrade Kit
    - Bought it for the 5.25" front panel switches/connections box, haven't touched any of the other pieces. Complete kit.
    $20 + shipping
    SOLD
    Intel Xeon E5 1650 v2
    - Basically a 4930K with Xeon features. Multiplier unlocked from the factory, not it is not an ES.
    $115 Sold!
    Intel Core i7 3930K
    - May have some degradation but appears to run fine at 1.25v. IHS is stained with old metallic TIM, cleaned it best as I could.
    $50 Sold!
    Hynix 4GB DDR3-1333 SODIMM
    - Single 4GB Stick
    $7 Sold!
    Danger Den AMD/Intel CPU Block
    - Ancient Bare-Copper CPU Block that fits AMD 754/939/AM1,2,3 Sockets, Intel 775, 115x, 1366 and possibly 2011.
    $15 Sold!
    Swiftech MC-RES Micro Reservoir
    - G1/4 threaded, 4x ports (2x in/out and 1x drain, 1x fill). Comes with mounting brackets and hardware.
    $15 Sold!
    ASUS P9X79-E WS
    - Board only. Has a small chip in the PCB in one corner but doesn't appear to affect anything.
    $175 Sold!
    EK Supremacy MX AMD CPU Waterblock
    - Will come with original box and all accessories. I also have some LGA 115x/1366 bracket hardware and backplate for it if you'd like. Backplate I have is 115x only. Original hardware fits all AMx sockets and possibly 754/939.
    $50 Sold!
    Assorted EK 90-degree Rotating G1/4 Fittings
    - 4x Matte Black
    - 2x Gunmetal
    $3 each + shipping - Sold!
    EVGA GTX 760 2GB GDDR5 w/ ACX Cooler
    - EVGA 02G-P4-3769-KB
    - Card only.
    $110 Sold!
    Antec 900 Modified - ATX
    - Modified it to mount a 180x180mm Radiator/Fan setup on top. Has a ghetto metal cover for the old top holes that we're there for the old top panel. Has a 5.25" Front-Panel bay with power/reset switches, power/hdd lights, and 2x USB3 ports. Front-Panel bay from a Phanteks kit. I do have the original Antec 900 top panel with the 200mm fan if you would like it, it should just screw right back on.
    $35 + shipping Sold!
    ASUS SATA DVD-RW
    - DRW-2014L1T, believe it works fine.
    Free w/ other item(s). Sold!
    EVGA 80 Plus 400W
    - EVGA 100-N1-0400-L1
    $25 + shipping Sold!
    ASUS P8H67-M PRO
    - Comes with I/O Shield only.
    $40 Sold!
    Cooler Master Hyper 212 Evo
    - Comes with all mounting hardware and 1x fan. Might be missing the second fan bracket, will double-check.
    $20 + shipping Sold!
    EVGA GT 710 2GB DDR3 Low-Profile Passive PCI-E 8x
    - EVGA 02G-P3-2712-KR
    - Comes with a full-profile PCI bracket, supports 4K 60Hz over HDMI.
    $35 Sold!
    Thanks for looking! :)
  2. souwen
    souwen Gawd
    992
    Jan 25, 2004
    hmmm....
    6 VM gaming PC with 2 core/6GB ea.
    {NG}Fidel and Emission like this.
  3. Reefa_Madness
    Reefa_Madness Gawd
    949
    Mar 2, 2006
  4. Emission
    Emission 2[H]4U
    4,034
    Dec 6, 2005
    PMs replied! I may adjust a price here and there to help things sell, but in the meantime, by all means shoot me an offer on anything!
    LGA 2011 CPUs SOLD! EVGA GTX 760, Ryzen 65W Cooler, Intel E8400 listed! Posted a handful of pics as well.
  5. Emission
    Emission 2[H]4U
    4,034
    Dec 6, 2005
    Some memory and water cooling sold, some prices dropped, bump!
  6. SamirD
    SamirD Gawd
    801
    Mar 22, 2015
    Bump for someone with a huge closet! :eek:
    That Mag monitor is a little workhorse. I picked one up at the local goodwill for using on systems which only have a vga. It also has the traditional 12v input so I'm sure these would be ideal for applications that can take advantage of that and the built-in speakers.
    Emission likes this.
  7. Emission
    Emission 2[H]4U
    4,034
    Dec 6, 2005
    Yep! I've had this monitor for ages and while it's not the best, it's still kicking!
    Uploaded more pictures, adding CM Storm Gaming Headest and some extra WC fittings. Ended up not having the I/O shield for the P9X79-E WS so lowered the price to accommodate that. Still have the cases and a few other things to take pictures of.
    Don't be shy, make offers! :)
  8. Emission
    Emission 2[H]4U
    4,034
    Dec 6, 2005
    Bump! Will try to get more pics up later today.
  9. Emission
    Emission 2[H]4U
    4,034
    Dec 6, 2005
  10. Emission
    Emission 2[H]4U
    4,034
    Dec 6, 2005
  11. Emission
    Emission 2[H]4U
    4,034
    Dec 6, 2005
  12. Emission
    Emission 2[H]4U
    4,034
    Dec 6, 2005
    Bump! Lowered a bunch of prices.
  13. Emission
    Emission 2[H]4U
    4,034
    Dec 6, 2005
  14. Emission
    Emission 2[H]4U
    4,034
    Dec 6, 2005
  15. Emission
    Emission 2[H]4U
    4,034
    Dec 6, 2005
    Bump! Added final pics, should include everything save for the Razer keyboard but I might need that. Will update the listing / post a pic depending on what happens.
    Updated specs on the Acer monitor, it is actually 1680x1050, not 1600x900.
  16. Emission
    Emission 2[H]4U
    4,034
    Dec 6, 2005
    Bump! Sold a few things, updated some prices, added some pictures.
  17. Emission
    Emission 2[H]4U
    4,034
    Dec 6, 2005
    Bump! Adding an SSD in a moment!
  18. Emission
    Emission 2[H]4U
    4,034
    Dec 6, 2005
  19. Emission
    Emission 2[H]4U
    4,034
    Dec 6, 2005
  20. Emission
    Emission 2[H]4U
    4,034
    Dec 6, 2005
  21. Emission
    Emission 2[H]4U
    4,034
    Dec 6, 2005
    Bump! GT 710 and 2 120mm fans sold! Some prices lowered!
  22. Emission
    Emission 2[H]4U
    4,034
    Dec 6, 2005
    Bump! Make offers, don't be shy!
  23. Emission
    Emission 2[H]4U
    4,034
    Dec 6, 2005
  24. Emission
    Emission 2[H]4U
    4,034
    Dec 6, 2005
  25. Emission
    Emission 2[H]4U
    4,034
    Dec 6, 2005
