Fry's weekend MB/CPU combo deals
Mohonri
I originally posted this in the Distributed Computing subforum (go there--we need your help to get into the #1 spot!), then thought it might be appropriate to post it here.
I just snagged the Fry's ad for this weekend. If you're looking for dirt cheap....well, they don't have any $70 MB/CPU combos this week. These combos are in the Houston area, but often the same deals are available in other areas. Here's what they have:
Pentium4 530J (3GHz, 800MHz FSB) with ECS MB - $160
Athlon64 3000+ (Socket754) with ECS MB - $130
And the more expensive stuff:
Athlon x2 64 4200 with Asus A8N-SLI - $650
Athlon 64 3800 with Gigabyte GA-K8NF-9 (NF4) - $430
Athlon 64 3200 with Gigabyte GA-K8NSC-939 (NF3) - $270
Fry's will probably have a $70 special Sat, Sun or Mon. They did the same thing last week. Finally wising up, I think. :D
Hmm.
Baseline, what would that consist of? A Sempron S754 processor and motherboard? Just wondering.
feigned said:
Hmm.
Socket A Sempron 2500+ retail or 2600+ OEM, cheapo motherboard, around $70.
I can't wait until the Socket A Semprons finally die. Then the cheap AMD combos will be S754 Semprons. :D The motherboards usually come out free, so that means a 2600+ & S754 board for $80 or so.
Hey, what did i tell ya?
http://latimes.p2ionline.com/shoppi...=8927450&type=cat&area=rop&adid=1322587&pop=1
Sempron 2600+ bare CPU with 1 year warranty and cheapie Socket A motherboard for $64.99.
The motherboard seems to be this one: http://www.pcchipsusa.com/prod-m848aluv21.asp. The CPU should overclock to 2.2GHz @ 400MHz FSB on that board. It might require a small voltage bump with conductive ink though.
the rest of the ad: http://latimes.p2ionline.com/shoppingchannel/content/index.aspx?webstoryid=8927437&area=rop&type=cat
I figured you would be. :p
We actually have a Fry's up in Indianapolis now, but I don't think I'll be making the trip for Socket A. Would make a decent budget system though. :)
