Front panel jack question.
YOHAN14344
My case (Chembro Gaming Bomb II) has some I/O for headset and mic at the front... but when I connect it to the motherboard, it doesn't work. I think it's because I am using Sound Blaster and when I disabled the M/B's audio.
So is there a way for me to connect those front I/O to Sound Blaster? :confused:
Depending on the soundblaster it might have jumpers on the card for other inputs. Otherwise, check out the frontx solution posted above.
