Foxconn NF-4K8MC
Alyosha
Having issues with the system below
-Motherboard mentioned in the title
-939 Pin A64 3500
-1 Gig RAM 2x512
-Gigabyte GF 6200 TC
-160 gig PATA harddrive
-Lite-On DVD burner
I started working on this about a month ago. I put the system together and it wouldn't POST; only the fans spun up, nothing else. I checked all the components except the processor as I didn't have another 939 pin board to test on. Everything else seemed fine so I RMA'd the mother board. Got a new board and had the same problem. I RMA'd the processor, got a new one and had the same problem.
I had tested the power supply (a 350 Watt mATX unit that came with the case I bought) in my own machine and my machine had booted so I figured that wasn't the problem. But, when I tested my powersupply in the machine in question I got it to POST. I had an extra power supply around which I used to try and set up this machine even though it didn't fit in the mATX case I'm using. The machine would run but was unstable. I figured this was due to the extra PSU being a cheap 300 Watt unit with a 20 pin ATX connector. I ordered a new 350 watt mATX PSU with a 24 pin ATX connector and got it today.
As you're no doubt guessing, it still doesn't work. This is by no means a high end machine so I have to assume that 350 watts is sufficient. So, this motherboard won't seem to run with a 24 pin PSU even though its designed to use one. It will run unstably with a 20 pin PSU. This is the only factor I can find that is causing the machine not to POST. Am I missing something? Any insight would be much appreciated.
you need a quality power supply.ck your 12 volt rail and see what specs are.you should have at least 20 amps on the 12 volt line.if you have a dvom ck the voltage output.this setup i would use nothing less than a 400w name brand p/supply with either the 20 pin or 24 pin depending on what your mobo has.if you get a power supply with a 24 pin you can use the adapter to reduce it to 20 pins.its not reccomended to use the 20 to 24 pin adapter.you can check this out with any of the p/supply companies.ck put pc power and coolings info on this subject on there website.you can always take the p/supply to your next upgrade if you buy a 24 pin setup.the problems you have are classic weak power...
good luck.i went through this a few weeks ago on a simular build.
