Korialstrasza
- Jan 21, 2004
Heya,
With windows XP, what's the difference between quick format and normal format? I've always used normal, but have wondered exactly what the difference is.
Secondly, if I am installing windows and I just formatted the HD (normal not quick) then exit the xp installation, restart computer, re-enter the installation, do I have to reformat the HD again? or is it still fine from the last formatting a few moments ago and I can use the "leave as be" option or whatever.
Thanks dudes.
Thanks dudes.
