- Aug 9, 2009
Pretty straight forward question: Can you GPU/CPU fold via a Guest OS on a machine using ESXi as the host OS?
Oh well. That was one of the major appeals of ESXi, it looked simple to setup.
I guess I will have to revert back to my original plan of having Windows as the Host OS so I can fold and run VM's
Just set the OI VM to Normal or high priority and the BOINC VM to low priority and everything should be fine. I folded on ESXi and it works well. They can even share cores. So give 4 to BOINC and 4 to OI and it should be just fine. You can try a second BOINC vm and see where that goes.
Just make sure not to overallocate ram. So ram for VM's + ram overhead (usually 10% of what is on VM's) + ram for ESXi 2 gigs.
And be careful with disk space if you overallocate and it runs out all VM's stop and you have to delete stuff until they can start.
Good luck!
