Im new to water cooling. This will be my first build. Any advise you may have would be awsome. I'll make sure to post pictures once its all done.
Im planning on setting the loop up like this.
Pump -> Rad -> CPU -> Chipset -> GPU1 -> GPU2 -> Res -> Pump
Does this sound like a prety good flow?
Also will the CSP-MAG pump have enough power to push through this many blocks?
W/C parts:
MAZE4 Power Kit
MAZE4 CPU Block
Black Ice Xtreme Radiator
Danger Den CSP-MAG 12V Pump
DDBay Reservoir High Density Polyehylene
Danger Den ASUS A8N MAZE4 Chipset Block
2x Danger Den Acetal MAZE4 GPU
Specs for system:
A64 3200+ Winchester
A8N-SLI Deluxe
2x Asus 6600GT cards in SLI.
2x 512mb Cricial Ballistix PC3200
Antec Sonata Case
W/C parts:
MAZE4 Power Kit
MAZE4 CPU Block
Specs for system:
A8N-SLI Deluxe
Antec Sonata Case
