I'm thinking about trying for a TEC system for my CPU, and am wondering how awful an Apogee is to cool the hot plate/side. The cold side (and I'll be sure to get a cold plate) will be on a topless 165.
Other question is about sealing: what should I use to seal the pin holes for my 939 socket? Is there anything home-depot-able (read: cheap) or should I be buying dielectric grease online? I kind of assumed that if I make a neoprene guard around the outside and then fill the inside with pretty much anything that will be ok, but I wasn't sure about the pins due to needing electrical conductivity (apparently computers are bad without it!).
