First time makin gaming rig. need help.
Medsor
Hey.
This is my first time fully building a comp my self, I've helped build comps befor and have messed around fixing messed up comps so basicly I know how to put one together and I need help with what I should buy. I think I would like to go with a DFI Lanparty MoBo, AMD 939skt CPU, I heard G.Skill RAM is good, and Im not sure about the graphics card cause Im not sure of the type of MoBo Im getting I dont know if it would be worth going with a SLI Mobo cause my budget isnt that big so maybe just go with something like DFI Lanparty nF4 ULTRA-D. Im open to all suggestions. thanks
Definately go the SLI route even if you can't get two vid cards now. You can pick up a second one later much cheaper.
Steven
When the time comes, today's single cards will become "slow", and you'll be glad you have a board that can hold a second one, so even if you buy 1 card now, SLI/Crossfire can always be a welcome upgrade. :D -Mark
somone on another forum recamended these parts
CPU: Opteron 165 - $328
http://www.newegg.com/Product/Product.asp?Item=N82E16819103588
motherboard: DFI UT NF4 Board - $116
http://www.newegg.com/Product/Product.asp?Item=N82E16813136159
GPU: eVGA 7800GT - $265
http://www.newegg.com/Product/Product.asp?Item=N82E16814130256
RAM: 1gb stick of g.skill extreme ($100 - CAS 2)
http://www.newegg.com/Product/Product.asp?Item=N82E16820231031
psu: Fortron 450w - $50
http://www.newegg.com/Product/Product.asp?Item=N82E16817104954
this looks good but I dont know much. its not SLI but Im still not sure if I should go with that on my budget.
I've never heard of Forton.
I'd stick with the brands I've abused and they still work!
Antec, Enermax, And sparkle.
I've heard OCZ, Silent Pc, Thermaltake also makes good ones.
Forton has been making PSU's for a long time and are very rock solid, but for a gaming machine, you might want something that has some more juice depending on what you have in that Forton.
u can OC the Opteron 165 up to like 2.8 w/ good cooling (more cache)
but the X2 3800+ has also hit those speeds
ur setup is nice Rox1co but I think Ill be wanting to do some overclocking and I would like to learn how to mess with the bios and stuff so I wanna try and go with a dfi mobo. so should I go with the opteron if Im planing on overclocking?
oh yeah baby :) i really wanna get better stuff to OC but i'm on a budget :(
if the extra $30 is no problem for u, then go for it! and i hear the Heatsink/Fan is better on the Opteron 165
but hey, if you already have a Heatsink/Fan or wanna buy an aftermarket Heatsink/Fan, u can find the Opteron 165 @ Monarch for $175 after rebate :p (i can't seem to find it at the moment, i'll keep looking for u tho)
well I used to play Dark Age of Camelot and I was thinkin of maybe getting back into that once my rig is built or maybe finding a new game. I also play Counter-Stike. so mostly mmorpg games.
would it be good to go with the setup I said befor and just upgrade the MoBo to a DFI that supports SLI and a SLI power supply like this?
MoBo: DFI Lanparty UT NF4 SLI-DR Expert - $178
http://www.monarchcomputer.com/Merc...ore_Code=M&Product_Code=110372&AFFIL=hhd&NR=1
RAM: G.SKILL 2GB (2 x 1GB) 184-Pin DDR SDRAM - $150
http://www.newegg.com/Product/Product.asp?Item=N82E16820231047
HD: Western Digital Caviar SE16 250GB 3.5" SATA 3.0Gb/s - $96
http://www.newegg.com/Product/Product.asp?Item=N82E16822144701
PSU: Antec TRUEPOWERII TPII-550 550W - $84
http://www.newegg.com/Product/Product.asp?Item=N82E16817103931
do you want all of this brand new? cuz it's gonna be expensive :p
since you really wanna learn to OC, i'd say yeah go for it. can't go wrong with DFI
save urself money n get the gpu+mobo combo :D
since u wanna OC, get this instead http://www.newegg.com/Product/Product.asp?Item=N82E16820231021
i got mine for $88 at zipzoomfly http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=101220-12 - if it doesn't hit $88 again, at least u don't have to pay for shipping
yeah good PSU, at least we'll have something in common ;)
Medsor said:
oh heh sorry. is that a good mobo?
scroll back up and read my replies ... i'm unsubscribing to this thread now since you don't read replies
good luck with your build, it'll be fun :)
I have not read the entire thread, but if you are still thinking about SLI, that Fox--something PSU will not cut it at 450watts. Even if you plan on buying the second card later, be sure you still get a SLI PSU.
k you didnt specify weather your an ati person or an nvidia person, however,
with $1200 i wouldnt upgrade now, theres am2 coming out, nforce 5 coming out, 7900 coming out, this is all in the next few months too, so keep the money, and buy later.
but if you really really need an upgrade (ex on agp) just get a 6800, there going for < $200.
my two cents.
Yea Im not buyin the 450w Im getting a 550w sli one. Ive only bought a motherboard so far. the DFI lanparty UT nf4 SLI Expert. so maybe Ill hold off on buying the graphics cards for now. do u know a site that has good previews of some of those new cards comin out?
thx for the look out to both of u :)
o and Im not sure which I like more, ATI or Nvidia, Ive only really had a ATI and this is gonna be my first real gaming rig. so if anyone has opinions on the difference between them Ill apreciat the info.
you'll get differing opinions (some with supporting benchmarks, even), but to me 2 gig of ram was an immediately noticeable performance improvement on a dual core system, even in little things like windows explorer performance. It really depends on how much multitasking you do, but I myself tend to fully endorse 2 gig now that I've run it for awhile.
oops sorry I got confused about the am2 and nforce5 thing. thought u were talkin about graphics cards. heh Im still new to this.
k thats just an invite to start a flamming war, so be4 anyone can start, look at the benchmarks. make your own opinion, cuz i have learned thru experiance, some ppl arnt looking for the best deals, some people are loyal to companys :( . but right now (Feb 27 7:40 pm pacific time) the X1900 is the best card. however, mid march, the 7900 is coming out. and it will own the X1900. these companys leap frog each other, all the time.
Nvidia also leaves more the to chipset maker. i mean look at all the ati cards. they all look the same. the nvidia cards, some have the standard aluminum heat sink w/ fan. most have custom fans, on custom boards, with custom performances. soo yea.
also, if your a do-it-yourself-er you should get one of those arctic cooling fans. they really can squeeze a coupled hundred 3dmarks out of your board.
and nice choice on mobo. im getting one of those too :D
I bought a 7800gt with my last upgrade, and was disappointed. No matter what others say, I see a distinct difference between nvidia and ati in image quality, with ati taking the lead. Textures on ati cards just seem much cleaner across the board for some reason. Then again, thats just me, your mileage may vary.
dude thats all.. i dun wanna create a flam war but the numbers say different. im not saying nvidia is better then ati. the X1900 is slightly better then the 7800.
but i mean, theres no way, an ati X700 is gonna give you a "cleaner textures" compared to a 7800GT. like.. the numbers dont lie. your FPS doesnt lie. i mean if you bought a new monitor. thats huge. LCDs still havnt conquered the liquid crystal trail problem. so cleaner.... is not.... .......... no. i own both a X700PRO and a 6600GT, which are, more or less, exact compitition. first off cleaner is bull. on my BOX for the X700 they messed up. the dudes hand. the little alien dudes hand has aliasing. its true. so cleaner no.
and reamember you can tweak all that crap too. like im not calling you a newb, but get some AA and AS going. turn up your res. i gaurentee you a 7800GT can and will impress you. its there flagship core.
your entire post oozes ineptitude so I'll forgive you for having no idea what I'm talking about. You dont qualify texture filtering with things like "the numbers dont lie". Anyone who experienced the differences between the 5900 cards and the 9700/9800 series will know exactly what I'm talking about. The difference is still noticeable.
